Introdução
Use this guide to replace and program the main control board in your GE top-load washing machine. A failed control board can cause the washer to not start, especially after other likely causes (like a harness issue) have been ruled out. Many GE top-load washers share the same board hardware across multiple models, so the replacement board must be programmed (set to the correct “personality”) for the exact washer model, or features may not work.
Common compatible board families that require programming include GE WH22X38441, GE WH22X38442, and GE WH22X38438.
O que você precisa
Passo 1 Prepare the washer for service
Move the washer so you can access the rear of the console.
Handle the control board by its edges and avoid touching components more than necessary.
Passo 2 Remove the console mounting screws
Use a 1/4-inch hex head screwdriver to remove the two long vertical screws at the rear of the console.
Passo 3 Release and lift the console
Push the console rearward by pressing or striking the console sides with a fist to release it.
Pivot the console up and away from the washer.
Disconnect the pressure hose from the console area if it prevents the console from opening far enough.
Passo 4 Remove the rear console panel
Slide the rear console panel from left to right to release it.
Lift the panel away from the console to improve access to the control board.
Passo 5 Document and disconnect the wiring
Take a photo of all wire and connector locations on the control board.
Disconnect all wiring harness connectors from the control board.
Passo 6 Remove the board retaining cover
Use a 1/4-inch hex head screwdriver to remove the four shallow screws from the plastic retaining cover.
Press the plastic tab on the upper corner of the board area to release the cover.
Lift the retaining cover off the control board.
Passo 7 Remove the control dial and control board
Pull the central control dial straight off the front of the console.
Lift the control board out of the console.
Passo 8 Position the new control board
Set the new control board into the console and align it with the control knob hole.
Align the board with the four mounting posts used by the retaining cover screws.
Reinstall the plastic retaining cover, seating the upper corner post first so it snaps into place.
Use a 1/4-inch hex head screwdriver to install the four retaining cover screws.
Passo 9 Reinstall the dial and reconnect all connectors
Press the control dial onto the new board shaft, aligning the flat on the knob with the flat on the shaft.
Reconnect all wiring harness connectors to the control board.
Reconnect the gray pressure hose to the sensor connection.
Passo 10 Set the console back onto the washer
Slot the console into the washer top, making sure the console posts on both sides seat into the washer top.
Passo 11 Power on for programming
Move the washer to an outlet and plug it in.
Wait for the console lights to flash, indicating the washer is ready to be programmed.
Passo 12 Find the correct personality for the washer model
Find the washer model number on the model tag by raising the lid.
Use the programming instructions for the exact control board model to find the matching personality for the washer model.
Passo 13 Program the control board personality
Press the Start/Pause button repeatedly until the console light pattern matches the correct personality for the washer model.
Press and hold the Start/Pause button for 3 to 5 seconds to save the selection.
Confirm programming by checking that all lights turn off.
Passo 14 Reprogram the personality using diagnostics if needed
Unplug the washer, then plug it back in to start fresh.
Press and hold the Start button, rotate the control dial about 180° counterclockwise, and then release the Start button.
Confirm diagnostic mode by checking for relay clicking and flashing lights.
Rotate the dial clockwise twice until the Rinse light is illuminated, then press Start to enable personality selection.
Rotate the dial to cycle through light combinations until the pattern matches the correct personality for the washer model.
Press and hold the Start button for 3 to 5 seconds to save the selection, and confirm that all lights turn off.
If the new board powers up and the washer accepts the correct personality setting, the replacement is complete. Recheck every connector and confirm the programming steps were followed exactly if the machine stays unresponsive or the board will not configure. Repair didn't go as planned? Ask our Answers community for help.
