Ir para o conteúdo principal
GE Side-By-Side Refrigerator Ice Auger Motor Replacement
O que você precisa
  1. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice bin: passo 2, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice bin: passo 2, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice bin: passo 2, imagem 3 %32
    • Grasp the ice bin and lift it upward slightly.
    • Pull the bin out of the freezer compartment and remove it.
  3. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice maker cover: passo 3, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice maker cover: passo 3, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Remove ice maker cover: passo 3, imagem 3 %32
    • Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
  4. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Unfasten ice maker: passo 4, imagem 1 %32
    • Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
  5. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice maker: passo 5, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice maker: passo 5, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice maker: passo 5, imagem 3 %32
    • Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
  6. GE Side-By-Side Refrigerator Ice Auger Motor Replacement: passo 6, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement: passo 6, imagem 2 %32
    • Reposition the ice maker to the lower right, below the auger motor.
    • You may be able to rest it on a lower shelf.
    • The ice maker is still connected to the electrical supply. Don't try to remove it yet.
  7. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect ice maker: passo 7, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect ice maker: passo 7, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect ice maker: passo 7, imagem 3 %32
    • Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
    • This may take some force. You can try lifting the retainer clips with a small flat head screwdriver, but access is difficult.
    • Remove the ice maker from the freezer compartment.
  8. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Unfasten the ice auger motor: passo 8, imagem 1 %32
    • Use a 1/4" nut driver to remove the two screws securing the ice auger motor to its support brackets.
  9. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Free the ice auger motor from its support brackets: passo 9, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Free the ice auger motor from its support brackets: passo 9, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Free the ice auger motor from its support brackets: passo 9, imagem 3 %32
    • Lift the ice auger motor to the right to free it from the left hand support bracket.
    • Lower the ice auger motor to the left, forward and down to allow it to clear the right hand support bracket.
  10. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice auger motor assembly: passo 10, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice auger motor assembly: passo 10, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Reposition the ice auger motor assembly: passo 10, imagem 3 %32
    • Lower the auger motor assembly so that you can access the electrical connection.
  11. GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect and remove the ice auger motor assembly: passo 11, imagem 1 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect and remove the ice auger motor assembly: passo 11, imagem 2 %32 GE Side-By-Side Refrigerator Ice Auger Motor Replacement, Disconnect and remove the ice auger motor assembly: passo 11, imagem 3 %32
    • The ice auger motor connection is mounted at an angle.
    • Squeeze the locking tabs on the connector to release it from the socket and pull it out to disconnect it.
    • Remove the ice auger motor assembly.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.497 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.623 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 56
Ao todo: 648
