Ir para o conteúdo principal
GE Side By Side Refrigerator Ice Maker Replacement
O que você precisa
  1. GE Side By Side Refrigerator Ice Maker Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: passo 2, imagem 1 %32 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: passo 2, imagem 2 %32 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: passo 2, imagem 3 %32
    • Grasp the ice bin and lift it upward slightly.
    • Pull the bin out of the freezer compartment and remove it.
  3. GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: passo 3, imagem 1 %32 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: passo 3, imagem 2 %32 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: passo 3, imagem 3 %32
    • Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
  4. GE Side By Side Refrigerator Ice Maker Replacement, Unfasten ice maker: passo 4, imagem 1 %32
    • Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
  5. GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: passo 5, imagem 1 %32 GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: passo 5, imagem 2 %32 GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: passo 5, imagem 3 %32
    • Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
  6. GE Side By Side Refrigerator Ice Maker Replacement: passo 6, imagem 1 %32 GE Side By Side Refrigerator Ice Maker Replacement: passo 6, imagem 2 %32
    • Reposition the ice maker to the lower right, below the auger motor.
    • You may be able to rest it on a lower shelf.
    • The ice maker is still connected to the electrical supply. Don't try to remove it yet.
  7. GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: passo 7, imagem 1 %32 GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: passo 7, imagem 2 %32 GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: passo 7, imagem 3 %32
    • Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
    • This may take some force. You can try lifting the retainer clips with a small flat head screwdriver, but access is difficult.
    • Remove the ice maker from the freezer compartment.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.497 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.623 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 37
Últimos 30 dias: 173
Ao todo: 1,623
