Introdução
A leaking dispenser can drip detergent, water, and rust-inducing residue across the front of your GE front-load washer. When thorough cleaning does not solve the problem, exchanging the entire dispenser assembly restores proper flow and prevents further cabinet damage. Use this procedure to remove the original box, transfer the reed switch, and install a replacement unit.
O que você precisa
Passo 1 Remove the dispenser drawer
Pull the dispenser drawer forward until it stops.
Press firmly on the tab at the rear of the drawer and slide the drawer completely out of the housing.
Passo 2 Remove the screws behind the dispenser
Use a Phillips screwdriver to extract the five screws now exposed in the dispenser opening.
Passo 3 Free the interface panel
Lift the left side of the interface about twenty degrees then pivot it to the right and pull it away from the washer.
Passo 4 Free harness clips for extra slack
Press the three harness clips from the inside out if you need more room to maneuver the interface.
Passo 5 Move the water valves if needed
Unscrew the water valve assembly and pivot it upward to gain clear access to the dispenser body.
Passo 6 Disconnect upper hoses and wiring
Unhook the wire harness from the dispenser body.
Release the top hoses that run between the water valves and the dispenser ports.
Slide the dispenser toward the rear to unlatch its right side from the chassis.
Passo 7 Disconnect the rear hoses
Loosen the clamps and pull off the four or five hoses attached to the back of the dispenser box.
Passo 8 Remove the front panel
Remove the three screws underneath the washer to release the lower edge of the front panel.
Extract the seven screws securing the panel to the bulkhead.
Unscrew the two screws holding the door-lock facade and the single screw securing the lock.
Lift the lock upward and push it rearward so it will not snag the panel.
Passo 9 Separate the front panel
Open the washer door, lift the panel upward, and pivot it away from the machine.
Passo 10 Detach the large front hoses
Remove the spring clamp and pull the primary tub hose off the dispenser spigot.
Disconnect the drain hose at the underside rear of the dispenser.
Release the small hose behind the metal plate next to the dispenser box.
Passo 11 Remove the dispenser box
With all eight hoses free, slide the dispenser box out of the cabinet.
Passo 12 Transfer the reed switch if required
Unclip the reed switch from the underside of the old dispenser and install it in the same location on the replacement box.
Passo 13 Position the new dispenser
Slide the dispenser into the front bulkhead opening and hold it in place.
Passo 14 Reconnect the hoses
Attach the remaining seven hoses one by one, securing each clamp firmly.
Passo 15 Route wiring and latch the dispenser
Route the harnesses into the molded channels on the dispenser body.
Slide the dispenser rearward until its rear hooks click into the washer chassis.
Passo 16 Attach front hoses to bulkhead
Reconnect the large front hose, aligning the molded notch with the dispenser groove.
Passo 17 Reinstall the front panel
Lift the door panel onto its four locator pegs and push it flush with the cabinet.
Reconnect the left-side harness, then replace the upper and lower mounting screws.
Passo 18 Secure the damper and gasket
Ensure the top damper is fully seated, then install its three mounting screws.
Passo 19 Install the gasket spring
Expand the spring with a door gasket spring tool and guide the wire around the gasket groove.
Use a small hook or screwdriver to press the wire fully home before releasing the tool.
Passo 20 Refit the door lock and facade
Position the door lock on its bracket and secure it with its screw.
Reattach the plastic facade using its two screws.
Passo 21 Reinstall the interface panel
Hook the interface onto the right-side post, pivot it down, and snap it into place.
Install the two coarse-thread center screws and the three fine-thread outer screws while holding the dispenser box flush.
Passo 22 Reinstall the dispenser drawer
Slide the dispenser drawer back onto its rails until it clicks fully home.
Passo 23 Reinstall the top panel
Lower the top panel onto the chassis and secure it with its rear screws.
Repair didn't go as planned? Ask our Answers community for help.
