Ir para o conteúdo principal
GE A1050 LCD Replacement
O que você precisa
  1. GE A1050 LCD Replacement, LCD: passo 1, imagem 1 %32 GE A1050 LCD Replacement, LCD: passo 1, imagem 2 %32 GE A1050 LCD Replacement, LCD: passo 1, imagem 3 %32
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
  2. GE A1050 LCD Replacement: passo 2, imagem 1 %32 GE A1050 LCD Replacement: passo 2, imagem 2 %32 GE A1050 LCD Replacement: passo 2, imagem 3 %32
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
  3. GE A1050 LCD Replacement: passo 3, imagem 1 %32 GE A1050 LCD Replacement: passo 3, imagem 2 %32 GE A1050 LCD Replacement: passo 3, imagem 3 %32
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
  4. GE A1050 LCD Replacement: passo 4, imagem 1 %32
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
Conclusão
Uma outra pessoa concluiu este guia.
oldturkey03
Membro desde: 09/29/10
836.380 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 2,122
