Ir para o conteúdo principal
GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement
O que você precisa
  1. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: passo 1, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: passo 1, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: passo 1, imagem 3 %32
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery: passo 2, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery: passo 2, imagem 2 %32
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Screws: passo 3, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Screws: passo 3, imagem 2 %32
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, LCD Cover: passo 4, imagem 1 %32
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Clock Radio: passo 5, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Clock Radio: passo 5, imagem 2 %32
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires Wire Tie: passo 6, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires Wire Tie: passo 6, imagem 2 %32
    • Using the wire cutters, carefully cut the plastic wire tie.
  7. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: passo 7, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: passo 7, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: passo 7, imagem 3 %32
    • Follow the wires to find where they connect to the printed circuit board (PCB). At the area of connect, two spots will be marked "DC+ and "DC-."
    • Apply the rubbing alcohol to the cotton swab end. Rub the end on the hot melt glue and wait for 30 seconds, then apply the alcohol to the hot melt glue again.
    • Use the tweezers to grab the softened hot melt glue. Pull the hot melt glue off of the clock radio.
  8. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Speaker: passo 8, imagem 1 %32
    • Grip the speaker.
    • Lift the speaker from the holder.
  9. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Two Screws: passo 9, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Two Screws: passo 9, imagem 2 %32
    • Locate the two 6mm screws on the PCB.
    • Using a Phillips #0 Screwdriver, unscrew the two 6 mm screws from the PCB.
  10. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: passo 10, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: passo 10, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: passo 10, imagem 3 %32
    • Raise the PCB.
    • With a ruler, measure 1.8 inches from the edge of the PCB. This solder is for the DC- battery wire connection.
    • Using a ruler, measure 9 mm from the edge of the PCB. This solder is for the DC+ battery wire connection.
  11. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires: passo 11, imagem 1 %32
    • Apply the tip of the heated soldering iron to the DC- solder.
    • Pull the wire from the backside of the PCB DC-.
    • Apply the tip of the heated soldering iron to the DC+ solder.
    • Pull the wire from the backside of the PCB DC+.
Conclusão
Uma outra pessoa concluiu este guia.
Dominick Giguere
Membro desde: 10/28/14
848 Reputação
Autoria de 6 guias
Um comentário
fuse resistence for mains supply for SL427 FM Radio and the same fuse resistence gets demaged frequently .....why?
Khurshid Ahmad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 11
Duração total: 1,569
