Ir para o conteúdo principal
GATEWAY NE56R09u Wireless Card Replacement
O que você precisa
  1. GATEWAY NE56R09u  Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, make sure the laptop is turned off.
    • Flip your laptop over so the bottom is facing up.
    Pergunte ao FixBot
    Comentar
  2. GATEWAY NE56R09u  Wireless Card Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
    Pergunte ao FixBot
    Comentar
  3. GATEWAY NE56R09u  Wireless Card Replacement: passo 3, imagem 1 %32
    • Lift the battery from the back casing to remove it.
    Pergunte ao FixBot
    Comentar
  4. GATEWAY NE56R09u  Wireless Card Replacement, Wireless card: passo 4, imagem 1 %32
    • Next, using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the wireless card.
    Pergunte ao FixBot
    Comentar
  5. GATEWAY NE56R09u  Wireless Card Replacement: passo 5, imagem 1 %32
    • Once the cover is off, locate the wireless card.
    Pergunte ao FixBot
    Comentar
  6. GATEWAY NE56R09u  Wireless Card Replacement: passo 6, imagem 1 %32
    • When located, remove the black and white cables from the wireless card. These are main and auxiliary antenna câbles.
    Pergunte ao FixBot
    Comentar
  7. GATEWAY NE56R09u  Wireless Card Replacement: passo 7, imagem 1 %32
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the M3x5.0mm screw with that is keeping the wireless card intact.
    Pergunte ao FixBot
    Comentar
  8. GATEWAY NE56R09u  Wireless Card Replacement: passo 8, imagem 1 %32 GATEWAY NE56R09u  Wireless Card Replacement: passo 8, imagem 2 %32
    • Remove the wireless card from the laptop
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, please follow these instructions in reverse order.
Luis Cardoso
Membro desde: 04/01/19
171 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 547
