Ir para o conteúdo principal
GATEWAY ML6720 Wireless Card Replacement
O que você precisa
  1. GATEWAY ML6720 Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32
    • Flip the laptop upside-down.
  2. GATEWAY ML6720 Wireless Card Replacement: passo 2, imagem 1 %32 GATEWAY ML6720 Wireless Card Replacement: passo 2, imagem 2 %32
    • Locate the wireless card cover, found on the middle-left section of the laptop as shown.
  3. GATEWAY ML6720 Wireless Card Replacement: passo 3, imagem 1 %32 GATEWAY ML6720 Wireless Card Replacement: passo 3, imagem 2 %32
    • Using the 1.5 mm Flathead Screwdriver, remove the cover screw at the top of the wireless card's cover plate.
  4. GATEWAY ML6720 Wireless Card Replacement: passo 4, imagem 1 %32
    • Pull the wireless card's cover plate up and off to reveal the card as shown.
  5. GATEWAY ML6720 Wireless Card Replacement: passo 5, imagem 1 %32
    • Remove the two wires connected to the wireless card.
  6. GATEWAY ML6720 Wireless Card Replacement: passo 6, imagem 1 %32 GATEWAY ML6720 Wireless Card Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Using the 1.5 mm Flathead Screwdriver, remove the two screws at the top left and right corners of the wireless card.
    • Slide the wireless card up and out of the compartment.
Conclusão
Nathan Da Silva
Membro desde: 10/19/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 233
