Ir para o conteúdo principal
GATEWAY ML6720 Keyboard Replacement
O que você precisa
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: passo 2, imagem 1 %32
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: passo 3, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 3, imagem 2 %32
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: passo 4, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 4, imagem 2 %32
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: passo 5, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 5, imagem 2 %32
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Turn the laptop on its backside with the stickers and barcode facing you.
  6. GATEWAY ML6720 Keyboard Replacement: passo 7, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 7, imagem 2 %32 GATEWAY ML6720 Keyboard Replacement: passo 7, imagem 3 %32
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  7. GATEWAY ML6720 Keyboard Replacement: passo 8, imagem 1 %32
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  8. GATEWAY ML6720 Keyboard Replacement: passo 9, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover
  9. GATEWAY ML6720 Keyboard Replacement: passo 10, imagem 1 %32 GATEWAY ML6720 Keyboard Replacement: passo 10, imagem 2 %32
    • Pull up the keyboard with your finger
Conclusão
Nathan Da Silva
Membro desde: 10/19/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 539
