Ir para o conteúdo principal
GATEWAY ML6720 Hard Drive Replacement
O que você precisa
  1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop on to its backside.
  2. GATEWAY ML6720 Hard Drive Replacement: passo 2, imagem 1 %32
    • Locate the hard drive at the bottom left corner of the laptop's backside.
  3. GATEWAY ML6720 Hard Drive Replacement: passo 3, imagem 1 %32 GATEWAY ML6720 Hard Drive Replacement: passo 3, imagem 2 %32
    • Insert the correct screwdriver mentioned in this guide.
    • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
  4. GATEWAY ML6720 Hard Drive Replacement: passo 4, imagem 1 %32
    • Slide the hard drive's cover plate out to the left and take it off.
  5. GATEWAY ML6720 Hard Drive Replacement: passo 5, imagem 1 %32
    • Pop the hard drive out of the compartment.
Conclusão
Nathan Da Silva
Membro desde: 10/19/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 342
