Ir para o conteúdo principal
Fused LED Light Replacement
O que você precisa
  1. Fused LED Light Replacement, Fused LED Light: passo 1, imagem 1 %32 Fused LED Light Replacement, Fused LED Light: passo 1, imagem 2 %32
    • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
    Pergunte ao FixBot
    Comentar
  2. Fused LED Light Replacement: passo 2, imagem 1 %32 Fused LED Light Replacement: passo 2, imagem 2 %32 Fused LED Light Replacement: passo 2, imagem 3 %32
    • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
    • The LED which doesn't lights up is detected as the faulty LED.
    Pergunte ao FixBot
    Comentar
  3. Fused LED Light Replacement: passo 3, imagem 1 %32
    • Using a knife or screwdriver, remove the faulty LED.
    • We need to replace it with a similar LED or a resistor.
    • Connecting the terminals directly can result in an increased current and multiple LED failure.
    Pergunte ao FixBot
    Comentar
  4. Fused LED Light Replacement: passo 4, imagem 1 %32 Fused LED Light Replacement: passo 4, imagem 2 %32
    • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
    Pergunte ao FixBot
    Comentar
  5. Fused LED Light Replacement: passo 5, imagem 1 %32
    • Connect the bulb to a power source to detect if it's working.
    Pergunte ao FixBot
    Comentar
  6. Fused LED Light Replacement: passo 6, imagem 1 %32 Fused LED Light Replacement: passo 6, imagem 2 %32
    • Finally, twist the light-diffusing dome back on the light bulb.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
1Comentário do guia
I have a large LED bulb with 8 banks of LEDs. The bulb would flicker at times then stay illuminated for a period. After a short time doing this it would completely stop then come back on. It finally stopped working at all. I engineered myself a couple leads from some old multimeter leads I had collecting dusk. I attached those to a fresh 9v battery then checked each bank of LED. All illuminate as quickly as I touch the leads to the first LED in each bank. What’s the issues with this bulb? It’s not due to a bad LED and breaking the continuity. I also prior to testing with the battery went through each bank getting a solid tone so there’s no loss of power from ATo Z. I’m open to suggestions based on your experience tackling this issue. It’s my first rodeo with the LED bulb. Thanks for your help.
Farron - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 154
Ao todo: 9,935
