Ir para o conteúdo principal
Fujitsu Lifebook Stylistic Q584 Battery Replacement
O que você precisa
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: passo 1, imagem 1 %32
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 2, imagem 1 %32
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 3, imagem 1 %32
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: passo 4, imagem 1 %32
      • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 5, imagem 1 %32
      • Remove the grey docking station port cover.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 6, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 7, imagem 1 %32
      • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: passo 8, imagem 1 %32
      • Pull up the cord that connects the battery to the motherboard
      Pergunte ao FixBot
      Comentar
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 9, imagem 1 %32
      • Remove seven 1mm screws using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 10, imagem 1 %32
      • Disconnect upper peripheral ribbons from motherboard.
      • Disconnect left peripheral ribbon from motherboard.
      Pergunte ao FixBot
      Comentar
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: passo 11, imagem 1 %32
      • Gently lift the battery from the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 37
Últimos 30 dias: 74
Ao todo: 3,959
