Ir para o conteúdo principal
Fujitsu Lifebook S6120 Screen Replacement
O que você precisa
  1. Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, imagem 3 %32
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: passo 2, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    Pergunte ao FixBot
    Comentar
  3. Fujitsu Lifebook S6120 Screen Replacement: passo 3, imagem 1 %32
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    Pergunte ao FixBot
    Comentar
  4. Fujitsu Lifebook S6120 Screen Replacement: passo 4, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 4, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Fujitsu Lifebook S6120 Screen Replacement: passo 5, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 5, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 5, imagem 3 %32
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    Pergunte ao FixBot
    Comentar
  6. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, imagem 3 %32
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    Pergunte ao FixBot
    Comentar
  7. Fujitsu Lifebook S6120 Screen Replacement: passo 7, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 7, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, imagem 3 %32
    • Push the secure clips outward.
    • The Adapter should pop up.
    Pergunte ao FixBot
    Comentar
  9. Fujitsu Lifebook S6120 Screen Replacement: passo 9, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 9, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 9, imagem 3 %32
    • Use tweezers to remove the wires from the Adapter.
    Pergunte ao FixBot
    Comentar
  10. Fujitsu Lifebook S6120 Screen Replacement: passo 10, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 10, imagem 2 %32
    • Take out the Adapter and carefully pull the wires out from the metal casing.
    Pergunte ao FixBot
    Comentar
  11. Fujitsu Lifebook S6120 Screen Replacement, Screen: passo 11, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement, Screen: passo 11, imagem 2 %32
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
    Pergunte ao FixBot
    Comentar
  12. Fujitsu Lifebook S6120 Screen Replacement: passo 12, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 12, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 12, imagem 3 %32
    • Use a plastic opening tool to lift up both sides of the white tab.
    Pergunte ao FixBot
    Comentar
  13. Fujitsu Lifebook S6120 Screen Replacement: passo 13, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 13, imagem 2 %32
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
    Pergunte ao FixBot
    Comentar
  14. Fujitsu Lifebook S6120 Screen Replacement: passo 14, imagem 1 %32
    • Lift the screen up vertically
    Pergunte ao FixBot
    Comentar
  15. Fujitsu Lifebook S6120 Screen Replacement: passo 15, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 15, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 15, imagem 3 %32
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
    Pergunte ao FixBot
    Comentar
  16. Fujitsu Lifebook S6120 Screen Replacement: passo 16, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 16, imagem 2 %32
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
    Pergunte ao FixBot
    Comentar
  17. Fujitsu Lifebook S6120 Screen Replacement: passo 17, imagem 1 %32
    • Remove the 3mm screws with a Philips head #00
    Pergunte ao FixBot
    Comentar
  18. Fujitsu Lifebook S6120 Screen Replacement: passo 18, imagem 1 %32
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
    Pergunte ao FixBot
    Comentar
  19. Fujitsu Lifebook S6120 Screen Replacement: passo 19, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 19, imagem 2 %32
    • Lift the screen from the frame
    Pergunte ao FixBot
    Comentar
  20. Fujitsu Lifebook S6120 Screen Replacement: passo 20, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 20, imagem 2 %32
    • Remove the ribbon from the back of the screen
    Pergunte ao FixBot
    Comentar
  21. Fujitsu Lifebook S6120 Screen Replacement: passo 21, imagem 1 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 21, imagem 2 %32 Fujitsu Lifebook S6120 Screen Replacement: passo 21, imagem 3 %32
    • Use a pair of tweezers remove the white connector
    Pergunte ao FixBot
    Comentar
Conclusão
Jessi Gallant
Membro desde: 03/19/18
920 Reputação
Autoria de 7 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 1,492
