Ir para o conteúdo principal
Fujitsu Lifebook S6120 PCI Adapter Replacement
O que você precisa
  1. Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: passo 1, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: passo 1, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: passo 1, imagem 3 %32
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Fujitsu Lifebook S6120 PCI Adapter Replacement, Hinge Cover: passo 2, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, Hinge Cover: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    Pergunte ao FixBot
    Comentar
  3. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 3, imagem 1 %32
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    Pergunte ao FixBot
    Comentar
  4. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 4, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 4, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 5, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 5, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 5, imagem 3 %32
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    Pergunte ao FixBot
    Comentar
  6. Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: passo 6, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: passo 6, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: passo 6, imagem 3 %32
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    Pergunte ao FixBot
    Comentar
  7. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 7, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 7, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: passo 8, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: passo 8, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: passo 8, imagem 3 %32
    • Push the secure clips outward.
    • The Adapter should pop up.
    Pergunte ao FixBot
    Comentar
  9. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 9, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 9, imagem 2 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 9, imagem 3 %32
    • Use tweezers to remove the wires from the Adapter.
    Pergunte ao FixBot
    Comentar
  10. Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 10, imagem 1 %32 Fujitsu Lifebook S6120 PCI Adapter Replacement: passo 10, imagem 2 %32
    • Take out the Adapter and carefully pull the wires out from the metal casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
1Comentário do guia
Je suis vraiment intéressé merci.
Ravi de la leçon.
Jean Fella - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 30
Ao todo: 1,294
