Ir para o conteúdo principal
Fujitsu Lifebook S6120 Keyboard Replacement
O que você precisa
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: passo 2, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    Pergunte ao FixBot
    Comentar
  3. Fujitsu Lifebook S6120 Keyboard Replacement: passo 3, imagem 1 %32
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    Pergunte ao FixBot
    Comentar
  4. Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, imagem 2 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, imagem 2 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, imagem 3 %32
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    Pergunte ao FixBot
    Comentar
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, imagem 2 %32 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, imagem 3 %32
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    Pergunte ao FixBot
    Comentar
  7. Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, imagem 1 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, imagem 2 %32 Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jessi Gallant
Membro desde: 03/19/18
920 Reputação
Autoria de 7 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 1,643
