Ir para o conteúdo principal
Fujitsu Lifebook A6110 RAM Replacement
O que você precisa
  1. Fujitsu Lifebook A6110 RAM Replacement, Battery: passo 1, imagem 1 %32 Fujitsu Lifebook A6110 RAM Replacement, Battery: passo 1, imagem 2 %32
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
    Pergunte ao FixBot
    Comentar
  2. Fujitsu Lifebook A6110 RAM Replacement: passo 2, imagem 1 %32
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
    Pergunte ao FixBot
    Comentar
  3. Fujitsu Lifebook A6110 RAM Replacement, RAM: passo 3, imagem 1 %32 Fujitsu Lifebook A6110 RAM Replacement, RAM: passo 3, imagem 2 %32
    • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
    • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
    Pergunte ao FixBot
    Comentar
  4. Fujitsu Lifebook A6110 RAM Replacement: passo 4, imagem 1 %32 Fujitsu Lifebook A6110 RAM Replacement: passo 4, imagem 2 %32 Fujitsu Lifebook A6110 RAM Replacement: passo 4, imagem 3 %32
    • Slide the cover towards the screw, and then lift the cover upwards.
    Pergunte ao FixBot
    Comentar
  5. Fujitsu Lifebook A6110 RAM Replacement: passo 5, imagem 1 %32 Fujitsu Lifebook A6110 RAM Replacement: passo 5, imagem 2 %32
    • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
    • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
    • If done correctly, the RAM card will eject at a 45 degree angle.
    Pergunte ao FixBot
    Comentar
  6. Fujitsu Lifebook A6110 RAM Replacement: passo 6, imagem 1 %32
    • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
    • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
    • If you choose to replace the other RAM card, repeat the process in Step 5.
    Pergunte ao FixBot
    Comentar
Conclusão
Cody Moniz
Membro desde: 10/19/16
422 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 1,329
