Ir para o conteúdo principal
Fujitsu LifeBook N3510 Wireless Module Replacement
O que você precisa
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Battery: passo 1, imagem 1 %32
      • Locate the two clips on the bottom of the computer that support the battery.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 2, imagem 1 %32
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: passo 3, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: passo 3, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: passo 3, imagem 3 %32
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 4, imagem 1 %32
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 5, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 5, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 5, imagem 3 %32
      • Use a spudger to partially lift the hinge cover.
      Pergunte ao FixBot
      Comentar
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 6, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 6, imagem 2 %32
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
      Pergunte ao FixBot
      Comentar
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 7, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 7, imagem 2 %32
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: passo 8, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: passo 8, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: passo 8, imagem 3 %32
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 9, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 9, imagem 2 %32
      • Use a spudger to release the ribbon cable from the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 10, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 10, imagem 2 %32
      • After the ribbon has been detached, carefully remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Metal Motherboard Cover: passo 11, imagem 1 %32
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 12, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 12, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 12, imagem 3 %32
      • Lift the cover with fingers and remove.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Display: passo 13, imagem 1 %32
      • Remove labeled screws.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 14, imagem 1 %32
      • Remove the screws from the bottom of the hinge as shown in the image.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 15, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 15, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 15, imagem 3 %32
      • Use a spudger to detach and remove cables from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 16, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 16, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 16, imagem 3 %32
      • Unplug highlighted cables from the wireless module.
      Pergunte ao FixBot
      Comentar
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 17, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 17, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement: passo 17, imagem 3 %32
      • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Top Palm Rest Cover: passo 18, imagem 1 %32
      • Remove the 4 labeled screws.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 19, imagem 1 %32
      • Remove screws from bottom of laptop as shown in the picture.
      Pergunte ao FixBot
      Comentar
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 20, imagem 1 %32
      • Lift the palm rest cover from the base of the laptop.
      • You may use spudger if needed, lift from the front corners as shown.
      Pergunte ao FixBot
      Comentar
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 21, imagem 1 %32
      • Great job! You have successfully removed the old palm rest cover.
      Pergunte ao FixBot
      Comentar
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: passo 22, imagem 1 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: passo 22, imagem 2 %32 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: passo 22, imagem 3 %32
      • Push securing clips outward, the wireless module will pop out.
      • Remove the wireless module.
      Pergunte ao FixBot
      Comentar
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: passo 23, imagem 1 %32
      • A picture of the removed wireless module is shown to the left.
      Pergunte ao FixBot
      Comentar
Conclusão
Neil Daniels
Membro desde: 01/17/11
1.411 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 5-18, Amido Winter 2011 Membro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membros
Autoria de 66 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 2,907
