Ir para o conteúdo principal
Fujitsu LifeBook N3510 Fan Replacement
O que você precisa
  1. Fujitsu LifeBook N3510 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two clips on the bottom of the computer that support the battery.
    Pergunte ao FixBot
    Comentar
  2. Fujitsu LifeBook N3510 Fan Replacement: passo 2, imagem 1 %32
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  3. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: passo 3, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: passo 3, imagem 2 %32 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: passo 3, imagem 3 %32
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    Pergunte ao FixBot
    Comentar
  4. Fujitsu LifeBook N3510 Fan Replacement: passo 4, imagem 1 %32
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
    Pergunte ao FixBot
    Comentar
  5. Fujitsu LifeBook N3510 Fan Replacement: passo 5, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 5, imagem 2 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 5, imagem 3 %32
    • Use a spudger to partially lift the hinge cover.
    Pergunte ao FixBot
    Comentar
  6. Fujitsu LifeBook N3510 Fan Replacement: passo 6, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 6, imagem 2 %32
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. Fujitsu LifeBook N3510 Fan Replacement: passo 7, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    Pergunte ao FixBot
    Comentar
  8. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: passo 8, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: passo 8, imagem 2 %32 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: passo 8, imagem 3 %32
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
    Pergunte ao FixBot
    Comentar
  9. Fujitsu LifeBook N3510 Fan Replacement: passo 9, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 9, imagem 2 %32
    • Use a spudger to release the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Fujitsu LifeBook N3510 Fan Replacement: passo 10, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 10, imagem 2 %32
    • After the ribbon has been detached, carefully remove the keyboard.
    Pergunte ao FixBot
    Comentar
  11. Fujitsu LifeBook N3510 Fan Replacement, Metal Motherboard Cover: passo 11, imagem 1 %32
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
    Pergunte ao FixBot
    Comentar
  12. Fujitsu LifeBook N3510 Fan Replacement: passo 12, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 12, imagem 2 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 12, imagem 3 %32
    • Lift the cover with fingers and remove.
    Pergunte ao FixBot
    Comentar
  13. Fujitsu LifeBook N3510 Fan Replacement, Fan: passo 13, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement, Fan: passo 13, imagem 2 %32 Fujitsu LifeBook N3510 Fan Replacement, Fan: passo 13, imagem 3 %32
    • Detach fan cable from motherboard.
    Pergunte ao FixBot
    Comentar
  14. Fujitsu LifeBook N3510 Fan Replacement: passo 14, imagem 1 %32
    • Remove labeled screws.
    Pergunte ao FixBot
    Comentar
  15. Fujitsu LifeBook N3510 Fan Replacement: passo 15, imagem 1 %32 Fujitsu LifeBook N3510 Fan Replacement: passo 15, imagem 2 %32
    • Remove fan.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Neil Daniels
Membro desde: 01/17/11
1.411 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 5-18, Amido Winter 2011 Membro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 4,410
