Introdução
This guide shows how to replace a Fujifilm X30 lens that may be cracked or damaged.
O que você precisa
Turn the camera upside down.
Place your thumb on the switch, and slide it towards the center of the camera.
Begin by removing the outside screws using a Phillips #000 Screwdriver:
Remove the three 3.6 mm silver screws located on the bottom of the camera.
Remove all four of the 4.7 mm screws from the sides of the camera.
4 outras pessoas executaram este guia.
