Ir para o conteúdo principal
Fujifilm Instax Mini Eight Camera Shell Replacement
O que você precisa
  1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: passo 1, imagem 1 %32 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: passo 1, imagem 2 %32 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: passo 1, imagem 3 %32
    • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
    • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
    Pergunte ao FixBot
    Comentar
  2. Fujifilm Instax Mini Eight Camera Shell Replacement: passo 2, imagem 1 %32 Fujifilm Instax Mini Eight Camera Shell Replacement: passo 2, imagem 2 %32 Fujifilm Instax Mini Eight Camera Shell Replacement: passo 2, imagem 3 %32
    • Press the tab down in order to unlatch the film compartment cover.
    • Remove the film from the compartment (if any is present)
    • Remove the compartment cover completely.
    • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
    Pergunte ao FixBot
    Comentar
  3. Fujifilm Instax Mini Eight Camera Shell Replacement: passo 3, imagem 1 %32 Fujifilm Instax Mini Eight Camera Shell Replacement: passo 3, imagem 2 %32 Fujifilm Instax Mini Eight Camera Shell Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tools and spudger to safely remove the front shell casing.
    Pergunte ao FixBot
    Comentar
  4. Fujifilm Instax Mini Eight Camera Shell Replacement: passo 4, imagem 1 %32 Fujifilm Instax Mini Eight Camera Shell Replacement: passo 4, imagem 2 %32
    • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
    • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
    • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Bo W
Membro desde: 10/02/12
1.037 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-1, Meier Fall 2015 Membro de USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Membros
Autoria de 26 guias
19Comentários do guia
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - Responder Compartilhar
but where near the exit? i cannot find it
Emily Birkler - Responder Compartilhar
It's at the top of the camera where you get picture.
xxx - Responder Compartilhar
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - Responder Compartilhar
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 47
Últimos 30 dias: 210
Ao todo: 71,225
