Ir para o conteúdo principal
Fujifilm Instax Mini 8 Capacitor Replacement
O que você precisa
    1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, imagem 3 %32
      • First, push in the lens and remove the two AA batteries.
      Pergunte ao FixBot
      Comentar
    2. Fujifilm Instax Mini 8 Capacitor Replacement: passo 2, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 2, imagem 2 %32
      • Open the rear compartment and remove the film cartridge.
      Pergunte ao FixBot
      Comentar
    3. Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, imagem 3 %32
      • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
      Pergunte ao FixBot
      Comentar
    4. Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, imagem 3 %32
      • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
      Pergunte ao FixBot
      Comentar
    5. Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, imagem 3 %32
      • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
      Pergunte ao FixBot
      Comentar
    6. Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, imagem 3 %32
      • Carefully pry out the capacitor with a spudger or plastic opening tools.
      Pergunte ao FixBot
      Comentar
    7. Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, imagem 1 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, imagem 2 %32 Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, imagem 3 %32
      • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Bo W
Membro desde: 10/02/12
1.052 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-1, Meier Fall 2015 Membro de USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Membros
Autoria de 35 guias
3Comentários do guia
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Responder Compartilhar
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Responder Compartilhar
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 33
Últimos 30 dias: 130
Ao todo: 28,914
