Ir para o conteúdo principal
Fujifilm FinePix Z5 LCD Screen Replacement
O que você precisa
    1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
      • Remove the two screws on the right side of the camera and the two screws on the left side.
      • Use a small #00 Phillips flat head screwdriver.
      • Keep all the screws in a container and the two different types separate.
      Pergunte ao FixBot
      Comentar
    2. Fujifilm FinePix Z5 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix Z5 LCD Screen Replacement: passo 2, imagem 2 %32
      • Remove the three screws from the bottom of the camera.
      • You need a three-prong screw driver for two of the three screws; keep these screws separate.
      Pergunte ao FixBot
      Comentar
    3. Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, imagem 2 %32 Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, imagem 3 %32
      • Remove the back by carefully flipping it open to the right side.
      • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
      Pergunte ao FixBot
      Comentar
    4. Fujifilm FinePix Z5 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z5 LCD Screen Replacement: passo 4, imagem 2 %32
      • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
      • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
      Pergunte ao FixBot
      Comentar
    5. Fujifilm FinePix Z5 LCD Screen Replacement: passo 5, imagem 1 %32 Fujifilm FinePix Z5 LCD Screen Replacement: passo 5, imagem 2 %32
      • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
      • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
      Pergunte ao FixBot
      Comentar
    6. Fujifilm FinePix Z5 LCD Screen Replacement: passo 6, imagem 1 %32
      • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 20
Últimos 30 dias: 53
Ao todo: 1,558
