Ir para o conteúdo principal
Fujifilm FinePix Z1 LCD Screen Replacement
O que você precisa
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 2 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 3 %32
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, imagem 2 %32
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 2 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 3 %32
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Conclusão
Carra
Membro desde: 01/30/18
533 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S2-G4, Johnson Spring 2018 Membro de Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 279
