Ir para o conteúdo principal
Fujifilm FinePix T500 Lens Gears Replacement
O que você precisa
  1. Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: passo 1, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: passo 1, imagem 3 %32
    • Unscrew the six 3.5mm Philips head from the outer casing.
    Pergunte ao FixBot
    Comentar
  2. Fujifilm FinePix T500 Lens Gears Replacement: passo 2, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 2, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 2, imagem 3 %32
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
    Pergunte ao FixBot
    Comentar
  3. Fujifilm FinePix T500 Lens Gears Replacement: passo 3, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 3, imagem 2 %32
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
    Pergunte ao FixBot
    Comentar
  4. Fujifilm FinePix T500 Lens Gears Replacement: passo 4, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 4, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 4, imagem 3 %32
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Fujifilm FinePix T500 Lens Gears Replacement, Lens: passo 5, imagem 1 %32
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
    Pergunte ao FixBot
    Comentar
  6. Fujifilm FinePix T500 Lens Gears Replacement: passo 6, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 6, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 6, imagem 3 %32
    • Pry off the center casing of the camera. Separate the top and side sections individually before fully removing the casing.
    Pergunte ao FixBot
    Comentar
  7. Fujifilm FinePix T500 Lens Gears Replacement: passo 7, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 7, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 7, imagem 3 %32
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
    Pergunte ao FixBot
    Comentar
  8. Fujifilm FinePix T500 Lens Gears Replacement: passo 8, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 8, imagem 2 %32
    • Pry the metal plate out using the spudger.
    Pergunte ao FixBot
    Comentar
  9. Fujifilm FinePix T500 Lens Gears Replacement: passo 9, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 9, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 9, imagem 3 %32
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
    Pergunte ao FixBot
    Comentar
  10. Fujifilm FinePix T500 Lens Gears Replacement: passo 10, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 10, imagem 2 %32
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
    Pergunte ao FixBot
    Comentar
  11. Fujifilm FinePix T500 Lens Gears Replacement, Lens Gears: passo 11, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove four 3.5 mm screws from the corners of the internal plate.
    Pergunte ao FixBot
    Comentar
  12. Fujifilm FinePix T500 Lens Gears Replacement: passo 12, imagem 1 %32
    • Slide the rectangular plastic frame to the side. You'll find a spring attaches the frame to the rest of the lens casing.
    • Disconnect the plastic frame from the spring.
    Pergunte ao FixBot
    Comentar
  13. Fujifilm FinePix T500 Lens Gears Replacement: passo 13, imagem 1 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 13, imagem 2 %32 Fujifilm FinePix T500 Lens Gears Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada neste passo:
    • The white and the black gears of the lens unit are responsible for the lens movement.
    • Using tweezers, adjust and replace these gears as needed. The white gear should be integrated with the rest of the unit. The black gear should occupy the entirety of its cavity.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Brian Lasher
Membro desde: 01/16/15
328 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 19-3, Blackwell Winter 2015 Membro de USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Membros
Autoria de 10 guias
1Comentário do guia
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
prabhu mandhar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 53
Ao todo: 1,224
