Ir para o conteúdo principal
Fujifilm FinePix S8630 Button Panel Replacement
O que você precisa
    1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: passo 1, imagem 1 %32
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Pergunte ao FixBot
      Comentar
    2. Fujifilm FinePix S8630 Button Panel Replacement: passo 2, imagem 1 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Pergunte ao FixBot
      Comentar
    3. Fujifilm FinePix S8630 Button Panel Replacement: passo 3, imagem 1 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Pergunte ao FixBot
      Comentar
    4. Fujifilm FinePix S8630 Button Panel Replacement: passo 4, imagem 1 %32 Fujifilm FinePix S8630 Button Panel Replacement: passo 4, imagem 2 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. Fujifilm FinePix S8630 Button Panel Replacement: passo 5, imagem 1 %32
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Fujifilm FinePix S8630 Button Panel Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S8630 Button Panel Replacement: passo 6, imagem 2 %32 Fujifilm FinePix S8630 Button Panel Replacement: passo 6, imagem 3 %32
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Pergunte ao FixBot
      Comentar
    7. Fujifilm FinePix S8630 Button Panel Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S8630 Button Panel Replacement: passo 7, imagem 2 %32 Fujifilm FinePix S8630 Button Panel Replacement: passo 7, imagem 3 %32
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Pergunte ao FixBot
      Comentar
    1. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, imagem 1 %32 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, imagem 2 %32 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, imagem 3 %32
      • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro de USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 758
