Ir para o conteúdo principal
Fujifilm FinePix S4200 Viewfinder Replacement
O que você precisa
    1. Fujifilm FinePix S4200 Viewfinder  Replacement, LCD Screen: passo 1, imagem 1 %32
      • Turn the camera off.
      • Turn the camera upside down so that the battery compartment is showing.
      Pergunte ao FixBot
      Comentar
    2. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 2, imagem 1 %32
      • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 3, imagem 1 %32
      • Rotate camera to the side where the speaker ports are located.
      • Remove the three 4 mm screws with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 4, imagem 1 %32
      • Turn the camera to the opposite side where the HDMI port is located.
      • Remove all five 4 mm screws with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 5, imagem 1 %32 Fujifilm FinePix S4200 Viewfinder  Replacement: passo 5, imagem 2 %32 Fujifilm FinePix S4200 Viewfinder  Replacement: passo 5, imagem 3 %32
      • Casing is fragile.
      • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
      • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
      Pergunte ao FixBot
      Comentar
    6. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 6, imagem 1 %32
      • Use force to pull apart the back casing from the camera.
      Pergunte ao FixBot
      Comentar
    7. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 7, imagem 1 %32
      • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
      Pergunte ao FixBot
      Comentar
    8. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 8, imagem 1 %32 Fujifilm FinePix S4200 Viewfinder  Replacement: passo 8, imagem 2 %32
      • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
      • Flip over LCD screen so that the left side of the metal plate is visible.
      Pergunte ao FixBot
      Comentar
    9. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 9, imagem 1 %32
      • Rotate the camera vertically so that it is easier to manage.
      • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
      Pergunte ao FixBot
      Comentar
    10. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 10, imagem 1 %32
      • Detach the metal plate from the motherboard.
      Pergunte ao FixBot
      Comentar
    11. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 11, imagem 1 %32 Fujifilm FinePix S4200 Viewfinder  Replacement: passo 11, imagem 2 %32
      • The orange ribbon cable is fragile.
      • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
      • Gently remove the LCD screen from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: passo 12, imagem 1 %32 Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: passo 12, imagem 2 %32
      • Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
      Pergunte ao FixBot
      Comentar
    2. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 13, imagem 1 %32
      • Carefully pull off the plastic cover from the view finder.
      Pergunte ao FixBot
      Comentar
    3. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 14, imagem 1 %32
      • Remove the two 3mm screws surrounding the viewfinder with a Phillips 000 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 15, imagem 1 %32
      • Orange ribbon is fragile.
      • Using the plastic opening tool, pull down the small black latch to remove the orange ribbon from the mother board.
      Pergunte ao FixBot
      Comentar
    5. Fujifilm FinePix S4200 Viewfinder  Replacement: passo 16, imagem 1 %32
      • Pull the viewfinder up to remove it from the body of the camera
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
CSU Fullerton, Team 1-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 1,277
