Introdução
If the memory card is full, no new photographs or video can be taken. No tools are required.
Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
Using your thumb, slide the hatch away from the center of the camera.
Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
Locate the memory card in the long, thin slot above the battery compartment.
Using your thumb, push the memory card farther into the camera.
The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
1Comentário do guia
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
