Introdução
Use this guide to replace the CMOS/RTC battery on your Framework laptop.
You'll only need a T5 bit screwdriver, a SIM eject tool (a paperclip will work too), and a replacement ML1220 CMOS battery for this guide. Note: The Framework laptop comes with a screwdriver with a T5 bit and a spudger.
Important: You may have trouble locating a suitable replacement CMOS/RTC battery for this laptop. Framework does not sell this component, but may ship it to you if you contact their support.
O que você precisa
Shut down the laptop and unplug the power cable if it is plugged in.
Close the laptop lid and place it upside down.
Locate the five T5 bits underneath the laptop. Using a screwdriver with a T5 bit, unscrew the five screws on the bottom cover.
The screw on the bottom left will not unscrew as far. This screw lifts the input cover slightly.
Flip the laptop over and open the lid.
The bottom right corner of the input cover should have lifted up to reveal a small gap which can be used to remove the input cover.
Carefully lift the input cover up from the bottom right corner using your finger or a pry tool. The input cover should be only held in place with magnets.
Locate the large black cable on the right side connecting the touchpad to the mainboard.
On the mainboard side of the cable, there is a large loop with a orange spot. Insert your finger through the loop and pull up.
You can now safely remove the input cover from the laptop.
Remember to connect the new touchpad cable to the mainboard before placing the new input cover on the laptop.
After removing the input cover, locate the CMOS/RTC battery, which is located near the middle of the mainboard, above the main battery and to the right of the SSD slot.
Locate the small hole just beneath the battery.
Using the sim eject tool or a paperclip, insert it into the small hole and apply light pressure downwards, prying the battery up and out of the socket.
The CMOS battery should have popped out of the holder.
You do not need to use the SIM eject tool to insert the new CMOS battery. Simply place the new CMOS battery in the holder.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Framework Laptop 13 answers community for help.
Uma outra pessoa concluiu este guia.
