Ir para o conteúdo principal
Framework Desktop Fastener Kit
O que você precisa
  1. Framework Desktop Fastener Kit, Fastener information: passo 1, imagem 1 %32 Framework Desktop Fastener Kit, Fastener information: passo 1, imagem 2 %32
    • The Fastener Kit contains the following:
    • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
    • Two large screws labeled "M6 ring screws"
    • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
    • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
    • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
    • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
    • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
    Pergunte ao FixBot
    Comentar
  2. Framework Desktop Fastener Kit, Top Panel screws: passo 2, imagem 1 %32 Framework Desktop Fastener Kit, Top Panel screws: passo 2, imagem 2 %32 Framework Desktop Fastener Kit, Top Panel screws: passo 2, imagem 3 %32
    • The two screws labeled "M6 ring screws" secure the Top Panel.
    Pergunte ao FixBot
    Comentar
  3. Framework Desktop Fastener Kit, Fan screws: passo 3, imagem 1 %32 Framework Desktop Fastener Kit, Fan screws: passo 3, imagem 2 %32
    • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
    Pergunte ao FixBot
    Comentar
  4. Framework Desktop Fastener Kit, Mainboard screws: passo 4, imagem 1 %32 Framework Desktop Fastener Kit, Mainboard screws: passo 4, imagem 2 %32
    • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
    Pergunte ao FixBot
    Comentar
  5. Framework Desktop Fastener Kit, Power supply screws: passo 5, imagem 1 %32 Framework Desktop Fastener Kit, Power supply screws: passo 5, imagem 2 %32
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
    Pergunte ao FixBot
    Comentar
  6. Framework Desktop Fastener Kit, Top plate screws: passo 6, imagem 1 %32 Framework Desktop Fastener Kit, Top plate screws: passo 6, imagem 2 %32 Framework Desktop Fastener Kit, Top plate screws: passo 6, imagem 3 %32
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
    Pergunte ao FixBot
    Comentar
  7. Framework Desktop Fastener Kit, Rear plate screws: passo 7, imagem 1 %32 Framework Desktop Fastener Kit, Rear plate screws: passo 7, imagem 2 %32 Framework Desktop Fastener Kit, Rear plate screws: passo 7, imagem 3 %32
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
    Pergunte ao FixBot
    Comentar
  8. Framework Desktop Fastener Kit, Side power supply screw: passo 8, imagem 1 %32 Framework Desktop Fastener Kit, Side power supply screw: passo 8, imagem 2 %32
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
    Pergunte ao FixBot
    Comentar
  9. Framework Desktop Fastener Kit, Power duct screws: passo 9, imagem 1 %32 Framework Desktop Fastener Kit, Power duct screws: passo 9, imagem 2 %32 Framework Desktop Fastener Kit, Power duct screws: passo 9, imagem 3 %32
    Pergunte ao FixBot
    Comentar
Conclusão
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
244.582 Reputação
Autoria de 1.203 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 264
