Ir para o conteúdo principal
Foldable Grocery Cart Wheels Replacement
O que você precisa
  1. Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 1 %32 Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 2 %32 Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 3 %32
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: passo 2, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 2, imagem 2 %32
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: passo 3, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 3, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 3, imagem 3 %32
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: passo 4, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 4, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 4, imagem 3 %32
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: passo 5, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 5, imagem 2 %32
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: passo 6, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 6, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 6, imagem 3 %32
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: passo 7, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 7, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 7, imagem 3 %32
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: passo 8, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 8, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 8, imagem 3 %32
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: passo 9, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 9, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 9, imagem 3 %32
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: passo 10, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 10, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 10, imagem 3 %32
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
Conclusão
Saba Aafreen
Membro desde: 06/30/21
232 Reputação
Autoria de 1 guia
2 comentários
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Responder
Need to replace axle it's bent
Constance Butler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 63
Últimos 30 dias: 207
Duração total: 11,116
