Ir para o conteúdo principal
Flipper Zero Button Replacement
O que você precisa
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
    Pergunte ao FixBot
    Comentar
  1. Flipper Zero Button Replacement, Remove the microSD card: passo 2, imagem 1 %32
    • Eject the microSD card by pressing it with your fingernail.
    Pergunte ao FixBot
    Comentar
  2. Flipper Zero Button Replacement, Remove the screws: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
    Pergunte ao FixBot
    Comentar
  3. Flipper Zero Button Replacement, Open the back cover: passo 4, imagem 1 %32 Flipper Zero Button Replacement, Open the back cover: passo 4, imagem 2 %32 Flipper Zero Button Replacement, Open the back cover: passo 4, imagem 3 %32
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
    Pergunte ao FixBot
    Comentar
  4. Flipper Zero Button Replacement, Seperate the chassis from the top cover: passo 5, imagem 1 %32 Flipper Zero Button Replacement, Seperate the chassis from the top cover: passo 5, imagem 2 %32
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
    Pergunte ao FixBot
    Comentar
  5. Flipper Zero Button Replacement, Disconnect the battery: passo 6, imagem 1 %32
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
    Pergunte ao FixBot
    Comentar
  6. Flipper Zero Button Replacement, Disconnect the ribbon cable: passo 7, imagem 1 %32
    iFixit Opening Picks (Set of 6)
    $4.95
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
    Pergunte ao FixBot
    Comentar
  7. Flipper Zero Button Replacement, Release the battery chassis: passo 8, imagem 1 %32 Flipper Zero Button Replacement, Release the battery chassis: passo 8, imagem 2 %32
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
    Pergunte ao FixBot
    Comentar
  8. Flipper Zero Button Replacement, Remove the ribbon cable: passo 9, imagem 1 %32 Flipper Zero Button Replacement, Remove the ribbon cable: passo 9, imagem 2 %32
    $4.95
    • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
    Pergunte ao FixBot
    Comentar
  9. Flipper Zero Button Replacement, Unscrew the the button chassis: passo 10, imagem 1 %32
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Flipper Zero Button Replacement, Seperate the button chassis: passo 11, imagem 1 %32 Flipper Zero Button Replacement, Seperate the button chassis: passo 11, imagem 2 %32 Flipper Zero Button Replacement, Seperate the button chassis: passo 11, imagem 3 %32
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
    Pergunte ao FixBot
    Comentar
  11. Flipper Zero Button Replacement, The button layout: passo 12, imagem 1 %32
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad).
    Pergunte ao FixBot
    Comentar
  12. Flipper Zero Button Replacement, Unlatching the buttons: passo 13, imagem 1 %32
    Flathead 1.5 mm Screwdriver
    $1.99
    Pergunte ao FixBot
    Comentar
  13. Flipper Zero Button Replacement, Remove the light diffuser: passo 14, imagem 1 %32 Flipper Zero Button Replacement, Remove the light diffuser: passo 14, imagem 2 %32 Flipper Zero Button Replacement, Remove the light diffuser: passo 14, imagem 3 %32
    • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Sebastian
Membro desde: 08/19/18
33.352 Reputação
Autoria de 72 guias
2Comentários do guia
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - Responder Compartilhar
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 82
Ao todo: 4,235
