Ir para o conteúdo principal
Flip Video Ultra USB connector Replacement
O que você precisa
    1. Flip Video Ultra USB connector Replacement, USB connector: passo 1, imagem 1 %32
      • Unlock the battery cover by sliding the switch to the unlock position.
      Pergunte ao FixBot
      Comentar
    2. Flip Video Ultra USB connector Replacement: passo 2, imagem 1 %32
      • Remove the battery cover by sliding it down the camera.
      Pergunte ao FixBot
      Comentar
    3. Flip Video Ultra USB connector Replacement: passo 3, imagem 1 %32
      • Remove the batteries.
      Pergunte ao FixBot
      Comentar
    4. Flip Video Ultra USB connector Replacement: passo 4, imagem 1 %32
      • Slide the black upper casing off from the device.
      • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
      Pergunte ao FixBot
      Comentar
    5. Flip Video Ultra USB connector Replacement: passo 5, imagem 1 %32 Flip Video Ultra USB connector Replacement: passo 5, imagem 2 %32
      • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Flip Video Ultra USB connector Replacement: passo 6, imagem 1 %32
      • Remove the top casing from the bottom to reveal the inner circuit board.
      Pergunte ao FixBot
      Comentar
    7. Flip Video Ultra USB connector Replacement: passo 7, imagem 1 %32 Flip Video Ultra USB connector Replacement: passo 7, imagem 2 %32
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      Pergunte ao FixBot
      Comentar
    8. Flip Video Ultra USB connector Replacement: passo 8, imagem 1 %32 Flip Video Ultra USB connector Replacement: passo 8, imagem 2 %32
      • Gently separate the circuit board from the casing.
      Pergunte ao FixBot
      Comentar
    9. Flip Video Ultra USB connector Replacement: passo 9, imagem 1 %32 Flip Video Ultra USB connector Replacement: passo 9, imagem 2 %32
      • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
      Pergunte ao FixBot
      Comentar
    10. Flip Video Ultra USB connector Replacement: passo 10, imagem 1 %32 Flip Video Ultra USB connector Replacement: passo 10, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Gently lift the usb connector using the Plastic opening tool.
      • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
      • The connector will be easier to remove if you wiggle the tweezers while lifting.
      Pergunte ao FixBot
      Comentar
    11. Flip Video Ultra USB connector Replacement: passo 11, imagem 1 %32
      • Fully remove the USB connector and replace it with the new USB connector.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nathaniel Ruf
Membro desde: 10/18/16
514 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-7, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Membros
Autoria de 10 guias
2Comentários do guia
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Responder Compartilhar
Where do you purchase the replacement usb connector?
DeEtte Moore - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 1,573
