Ir para o conteúdo principal
Flip Video Ultra Circuit Board Replacement
O que você precisa
    1. Flip Video Ultra Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
      • Unlock the battery cover by sliding the switch to the unlock position.
      Pergunte ao FixBot
      Comentar
    2. Flip Video Ultra Circuit Board Replacement: passo 2, imagem 1 %32
      • Remove the battery cover by sliding it down the camera.
      Pergunte ao FixBot
      Comentar
    3. Flip Video Ultra Circuit Board Replacement: passo 3, imagem 1 %32
      • Remove the batteries
      Pergunte ao FixBot
      Comentar
    4. Flip Video Ultra Circuit Board Replacement: passo 4, imagem 1 %32
      • Slide the black upper casing off from the device.
      Pergunte ao FixBot
      Comentar
    5. Flip Video Ultra Circuit Board Replacement: passo 5, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 5, imagem 2 %32
      • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Flip Video Ultra Circuit Board Replacement: passo 6, imagem 1 %32
      • Remove the top casing from the bottom to reveal the inner circuit board.
      Pergunte ao FixBot
      Comentar
    7. Flip Video Ultra Circuit Board Replacement: passo 7, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 7, imagem 2 %32
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      Pergunte ao FixBot
      Comentar
    8. Flip Video Ultra Circuit Board Replacement: passo 8, imagem 1 %32
      • Gently separate the circuit board from the casing.
      Pergunte ao FixBot
      Comentar
    9. Flip Video Ultra Circuit Board Replacement: passo 9, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 9, imagem 2 %32
      • Unscrew the single 1mm screw from USB housing unit.
      Pergunte ao FixBot
      Comentar
    10. Flip Video Ultra Circuit Board Replacement: passo 10, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 10, imagem 2 %32
      • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
      Pergunte ao FixBot
      Comentar
    11. Flip Video Ultra Circuit Board Replacement: passo 11, imagem 1 %32
      • Gently pry out the USB housing unit with the Ifxit Opening Tool.
      Pergunte ao FixBot
      Comentar
    12. Flip Video Ultra Circuit Board Replacement: passo 12, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 12, imagem 2 %32 Flip Video Ultra Circuit Board Replacement: passo 12, imagem 3 %32
      • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
      Pergunte ao FixBot
      Comentar
    13. Flip Video Ultra Circuit Board Replacement: passo 13, imagem 1 %32
      • Unscrew the camera housing unit from the plastic case.
      Pergunte ao FixBot
      Comentar
    14. Flip Video Ultra Circuit Board Replacement: passo 14, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 14, imagem 2 %32 Flip Video Ultra Circuit Board Replacement: passo 14, imagem 3 %32
      Ferramenta utilizada neste passo:
      • With tweezers, remove the microphone and USB connections.
      Pergunte ao FixBot
      Comentar
    15. Flip Video Ultra Circuit Board Replacement: passo 15, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 15, imagem 2 %32
      • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
      Pergunte ao FixBot
      Comentar
    16. Flip Video Ultra Circuit Board Replacement: passo 16, imagem 1 %32 Flip Video Ultra Circuit Board Replacement: passo 16, imagem 2 %32
      • Remove the single 2.1 mm screw and separate camera from the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nathaniel Ruf
Membro desde: 10/18/16
514 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-7, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 33
Ao todo: 1,069
