Ir para o conteúdo principal
Flip Video LCD Screen
O que você precisa
    1. Flip Video LCD Screen, Outer Shell: passo 1, imagem 1 %32 Flip Video LCD Screen, Outer Shell: passo 1, imagem 2 %32
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Pergunte ao FixBot
      Comentar
    2. Flip Video LCD Screen: passo 2, imagem 1 %32
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Pergunte ao FixBot
      Comentar
    3. Flip Video LCD Screen: passo 3, imagem 1 %32 Flip Video LCD Screen: passo 3, imagem 2 %32
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Pergunte ao FixBot
      Comentar
    4. Flip Video LCD Screen: passo 4, imagem 1 %32
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Pergunte ao FixBot
      Comentar
    5. Flip Video LCD Screen: passo 5, imagem 1 %32
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Pergunte ao FixBot
      Comentar
    1. Flip Video LCD Screen, Circuit Board: passo 6, imagem 1 %32
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Flip Video LCD Screen: passo 7, imagem 1 %32
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Pergunte ao FixBot
      Comentar
    3. Flip Video LCD Screen: passo 8, imagem 1 %32
      • Disconnect the USB port cable from the back side of the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Flip Video LCD Screen: passo 9, imagem 1 %32
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Pergunte ao FixBot
      Comentar
    1. Flip Video LCD Screen, LCD Screen: passo 10, imagem 1 %32
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Flip Video LCD Screen: passo 11, imagem 1 %32
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      Pergunte ao FixBot
      Comentar
    3. Flip Video LCD Screen: passo 12, imagem 1 %32
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth
Membro desde: 04/15/10
100 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 26-21, Regan Spring 2010 Membro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 5,732
