Ir para o conteúdo principal
Flash Motherboard
O que você precisa
  1. Flash Motherboard, Front and Back Covers: passo 1, imagem 1 %32 Flash Motherboard, Front and Back Covers: passo 1, imagem 2 %32 Flash Motherboard, Front and Back Covers: passo 1, imagem 3 %32
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Pergunte ao FixBot
    Comentar
  2. Flash Motherboard: passo 2, imagem 1 %32
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Pergunte ao FixBot
    Comentar
  3. Flash Motherboard: passo 3, imagem 1 %32
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Flash Motherboard: passo 4, imagem 1 %32 Flash Motherboard: passo 4, imagem 2 %32
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Pergunte ao FixBot
    Comentar
  5. Flash Motherboard: passo 5, imagem 1 %32
    • The camera should look like this once the front cover is removed.
    Pergunte ao FixBot
    Comentar
  6. Flash Motherboard: passo 6, imagem 1 %32 Flash Motherboard: passo 6, imagem 2 %32 Flash Motherboard: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  7. Flash Motherboard: passo 7, imagem 1 %32
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Pergunte ao FixBot
    Comentar
  8. Flash Motherboard, Flash Motherboard: passo 8, imagem 1 %32
    • Turn to the front of the camera.
    • Find the flash motherboard located behind the flash assembly on the top right.
    Pergunte ao FixBot
    Comentar
  9. Flash Motherboard: passo 9, imagem 1 %32
    • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
    • Once the cables are disconnected, you are now ready to install a new motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Jakub
Membro desde: 04/19/11
134 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-6, Regan Spring 2011 Membro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 4,480
