Ir para o conteúdo principal
Fix the Short in the Plug Guide
O que você precisa
  1. Fix the Short in the Plug Guide, Fix the Short in the Plug Guide: passo 1, imagem 1 %32
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
    Pergunte ao FixBot
    Comentar
  2. Fix the Short in the Plug Guide: passo 2, imagem 1 %32
    • Locate all exposed portions of the wire.
    • Tape over any exposed portions of the wire with electrical tape.
    • Use this power cord temporarily.
    Pergunte ao FixBot
    Comentar
  3. Fix the Short in the Plug Guide: passo 3, imagem 1 %32
    • Plug the power cord into the outlet and make sure the power cord is connected to the device. If not, connect the power cord to the back of the device.
    • Replace the damaged cable by purchasing a new cable at your local hardware store.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Equipe
Cal Poly, Team 7-50, Forte Fall 2012 Membro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 1,867
