Ir para o conteúdo principal
Fitbit Blaze Vibration Motor Replacement
O que você precisa
  1. Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, imagem 2 %32
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze  Vibration Motor Replacement: passo 2, imagem 1 %32
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 3 %32
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
    This step is not needed to change the battery . Not sure why it was included.
    Jason Y - Responder
  4. Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 3 %32
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
  5. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 3 %32
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  6. Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 3 %32
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  7. Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 3 %32
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  8. Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 3 %32
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  9. Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 3 %32
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  10. Fitbit Blaze  Vibration Motor Replacement: passo 10, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 10, imagem 2 %32
    • Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
    • Desolder the connection to remove the motor component.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
Conclusão
Adrian Borrego
Membro desde: 02/20/17
2.242 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Membros
Autoria de 15 guias
4Comentários do guia
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - Responder
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - Responder
what kind of motor can you replace this with?
dbick - Responder
Any idea what is the value of the C3 capacitor?
P J - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 27
Ao todo: 3,183
