Ir para o conteúdo principal
Fellowes T7CM On, Off, Reverse Switch Replacement
O que você precisa
  1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: passo 1, imagem 1 %32
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    Pergunte ao FixBot
    Comentar
  2. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 2, imagem 1 %32
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    Pergunte ao FixBot
    Comentar
  3. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 3, imagem 1 %32
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    Pergunte ao FixBot
    Comentar
  4. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 4, imagem 1 %32
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    Pergunte ao FixBot
    Comentar
  5. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: passo 5, imagem 1 %32
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
    Pergunte ao FixBot
    Comentar
  6. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 6, imagem 1 %32 Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 6, imagem 2 %32
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
IUPUI, Team 2-2, Baechle Fall 2016 Membro de IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 66
Ao todo: 4,463
