Ir para o conteúdo principal
Fast Fix Pool tiles Replacement
  1. Fast Fix Pool tiles Replacement, Pool tiles: passo 1, imagem 1 %32
    • Remove enough water from the pool, so you can start working.
    Pergunte ao FixBot
    Comentar
  2. Fast Fix Pool tiles Replacement: passo 2, imagem 1 %32
    • Get a hammer and chisel so you can start working.
    Pergunte ao FixBot
    Comentar
  3. Fast Fix Pool tiles Replacement: passo 3, imagem 1 %32
    • In this step , by using a hammer and a chisel , you must remove all the grout that can be found after removing the old tiles. The flat surface where you will placing your new tiles needs to be clean so that the new tile can be placed properly.
    Pergunte ao FixBot
    Comentar
  4. Fast Fix Pool tiles Replacement: passo 4, imagem 1 %32
    • In this step , you must take mix concrete concentrate and water together. After it has been mixed properly , you should wait 10 minutes so that the mixture can settle down.
    Pergunte ao FixBot
    Comentar
  5. Fast Fix Pool tiles Replacement: passo 5, imagem 1 %32
    • In this step , you must apply the concrete mixture to the back of the new tiles so that it can be later placed at the location where the old tiles were removed.
    Pergunte ao FixBot
    Comentar
  6. Fast Fix Pool tiles Replacement: passo 6, imagem 1 %32
    • Finally, you must wait 8 hours for the tiles to dry up. Once the pool tiles are checked to see if they are dry, you can then proceed to fill the pool up with water.
    Pergunte ao FixBot
    Comentar
Conclusão
Your pool is now repaired. You may proceed to swimming.
Abhishek Minhas
Membro desde: 07/21/20
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 248
