Ir para o conteúdo principal
Farberware FSTO100 Indicator Light Replacement
O que você precisa
  1. Farberware FSTO100 Indicator Light Replacement, Indicator Light: passo 1, imagem 1 %32
    • Make sure toaster is unplugged.
    • Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
    Pergunte ao FixBot
    Comentar
  2. Farberware FSTO100 Indicator Light Replacement: passo 2, imagem 1 %32
    • On the left hand side, unscrew the middle screw.
    Pergunte ao FixBot
    Comentar
  3. Farberware FSTO100 Indicator Light Replacement: passo 3, imagem 1 %32
    • Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
    Pergunte ao FixBot
    Comentar
  4. Farberware FSTO100 Indicator Light Replacement: passo 4, imagem 1 %32
    • Pull the black wires to remove the indicator light from the red tube.
    Pergunte ao FixBot
    Comentar
  5. Farberware FSTO100 Indicator Light Replacement: passo 5, imagem 1 %32 Farberware FSTO100 Indicator Light Replacement: passo 5, imagem 2 %32
    • Use scissors to cut open cord sheathing and peel back.
    Pergunte ao FixBot
    Comentar
  6. Farberware FSTO100 Indicator Light Replacement: passo 6, imagem 1 %32
    • Use the wire-cutters to remove the light bulb.
    Pergunte ao FixBot
    Comentar
  7. Farberware FSTO100 Indicator Light Replacement: passo 7, imagem 1 %32 Farberware FSTO100 Indicator Light Replacement: passo 7, imagem 2 %32
    • Solder the replacement light bulb back onto its original position.
    Pergunte ao FixBot
    Comentar
  8. Farberware FSTO100 Indicator Light Replacement: passo 8, imagem 1 %32
    • Use electrical tape to reseal the sheathing.
    Pergunte ao FixBot
    Comentar
  9. Farberware FSTO100 Indicator Light Replacement: passo 9, imagem 1 %32
    • Reinsert the indicator light back into the red tube.
    Pergunte ao FixBot
    Comentar
  10. Farberware FSTO100 Indicator Light Replacement: passo 10, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  11. Farberware FSTO100 Indicator Light Replacement: passo 11, imagem 1 %32
    • On the left hand side, screw the middle screw back in.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Tony Wang
Membro desde: 10/05/12
112 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-35, Regan Fall 2012 Membro de Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 1,209
