Ir para o conteúdo principal
Fan Coil Filter Replacement
O que você precisa
    1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: passo 1, imagem 1 %32
      • Clean the fan coil grilles using a paper towel and water.
      • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
      Pergunte ao FixBot
      Comentar
    2. Fan Coil Filter Replacement: passo 2, imagem 1 %32
      • Close off each adjustable damper.
      • This will ensure that the register grille does not get in the way later on during the filter removal.
      Pergunte ao FixBot
      Comentar
    3. Fan Coil Filter Replacement: passo 3, imagem 1 %32 Fan Coil Filter Replacement: passo 3, imagem 2 %32
      • Remove the screws from fan coil using a Phillips #1 screwdriver.
      • Open up the fan coil.
      Pergunte ao FixBot
      Comentar
    4. Fan Coil Filter Replacement: passo 4, imagem 1 %32
      • Use your hands to remove the filter from the fan coil.
      Pergunte ao FixBot
      Comentar
    5. Fan Coil Filter Replacement: passo 5, imagem 1 %32 Fan Coil Filter Replacement: passo 5, imagem 2 %32
      • Replace the fan coil filter.
      • Make sure to close the fan coil door after the filter replacement is completed.
      Pergunte ao FixBot
      Comentar
    6. Fan Coil Filter Replacement: passo 6, imagem 1 %32 Fan Coil Filter Replacement: passo 6, imagem 2 %32
      • Screw in closed the fan coil door.
      • Open up each of the adjustable dampers for better air flow.
      Pergunte ao FixBot
      Comentar
Conclusão
Following these steps, you will be able to replace the filter in your fan coil system.
Abukar Ahmed
Membro desde: 09/20/20
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 1,357
