Ir para o conteúdo principal
Fahrenheit FHT 125PRMR Power Cord Replacement
O que você precisa
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: passo 2, imagem 1 %32
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: passo 3, imagem 1 %32 Fahrenheit FHT 125PRMR Power Cord Replacement: passo 3, imagem 2 %32
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: passo 4, imagem 1 %32 Fahrenheit FHT 125PRMR Power Cord Replacement: passo 4, imagem 2 %32
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: passo 5, imagem 1 %32
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
Conclusão
4 outras pessoas executaram este guia.
Joshua Potts
Membro desde: 09/29/16
265 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Harley Fall 2016 Membro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Membros
Autoria de 4 guias
3Comentários do guia
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Responder
Where do you buy the power cord?
Dominique - Responder
probably available at electronic store
john john - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 2,555
