Ir para o conteúdo principal
Fahrenheit FHT 125PRMR Dial Replacement
O que você precisa
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: passo 1, imagem 1 %32
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: passo 2, imagem 1 %32
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: passo 3, imagem 1 %32 Fahrenheit FHT 125PRMR Dial Replacement: passo 3, imagem 2 %32
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: passo 4, imagem 1 %32 Fahrenheit FHT 125PRMR Dial Replacement: passo 4, imagem 2 %32
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: passo 5, imagem 1 %32
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: passo 6, imagem 1 %32 Fahrenheit FHT 125PRMR Dial Replacement: passo 6, imagem 2 %32
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: passo 7, imagem 1 %32
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: passo 8, imagem 1 %32
    • Using a soldering tool, remove the dial station by carefully desoldering the metal on the connecting pins to the motherboard.
    • Como soldar e dessoldar contatos
Conclusão
Nicolas Moreau
Membro desde: 09/29/16
180 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Harley Fall 2016 Membro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 28
Ao todo: 897
