Ir para o conteúdo principal
F. PanelDue Firmware Update
  1. F. PanelDue Firmware Update, Downloads: passo 1, imagem 1 %32
    • Download the latest stable firmware from the Duet Github and extract the zip file
    • Make sure you download the correct version. The PanelDue 5i and 7i both use the same firmware binary. The file you want is named "PanelDue-5.0i-7.0i.bin"
    • FYSETC documentation says to use the 5i/7i combined binary("PanelDue-5.0i-7.0i.bin") for their 5i and 7i screens. If you use the combined version for you FYSETC 5i/7i your color scheme will be incorrect.
    • You need to install "PanelDueFirmware-v3-7.0.zip" or "PanelDueFirmware-v3-5.0.zip"
    • Download and install Bossa
    Pergunte ao FixBot
    Comentar
  2. F. PanelDue Firmware Update, Connecting to your PC: passo 2, imagem 1 %32
    • Hold the erase button on the back of the PanelDue
    • Connect a USB Micro cable from your PC to your PanelDue. Release the erase button and press the reset button.
    • Identify the COM port the PanelDue is using.
    • Click Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT)
    Pergunte ao FixBot
    Comentar
  3. F. PanelDue Firmware Update, Flashing the Firmware: passo 3, imagem 1 %32
    • Once connected open Bossa.
    • Select the port in the dropdown. Click Browse and select the PanelDue firmware
    • Select the checkboxes for Erase all, Lock, and Boot from flash
    • Click Write. Bossa will load the firmware to the PanelDue. Once upload is complete, click Verify.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
8 outras pessoas executaram este guia.
David Husolo
Membro desde: 06/16/21
9.382 Reputação
Autoria de 33 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 2,035
