Ir para o conteúdo principal
ExoPC Slate Battery Replacement
O que você precisa
    1. ExoPC Slate Battery Replacement, Battery: passo 1, imagem 1 %32
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      Pergunte ao FixBot
      Comentar
    2. ExoPC Slate Battery Replacement: passo 2, imagem 1 %32 ExoPC Slate Battery Replacement: passo 2, imagem 2 %32
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      Pergunte ao FixBot
      Comentar
    3. ExoPC Slate Battery Replacement: passo 3, imagem 1 %32 ExoPC Slate Battery Replacement: passo 3, imagem 2 %32 ExoPC Slate Battery Replacement: passo 3, imagem 3 %32
      • Remove the tape covering the metal shield as shown in the image.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      Pergunte ao FixBot
      Comentar
    4. ExoPC Slate Battery Replacement: passo 4, imagem 1 %32
      • Remove tape from the side of the battery.
      • Disconnect the battery from the motherboard.
      • Gently remove the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
Aaron Moore
Membro desde: 10/30/18
217 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 41
Últimos 30 dias: 63
Ao todo: 914
