Introdução
The power button is pressed to power the device on or off. This guide shows how to replace the plastic button itself, not the components that make it work. If the plastic power button is damaged or otherwise needs replacement, follow this guide.
O que você precisa
Lay the device on a flat surface, with the screen facing the sufrace.
Using angled tweezers, remove the six rubber screw covers from the sockets.
Flip the device so the screen is facing you.
Four hidden retaining clips hold the pieces together even near each corner of the screen.
Insert a Jimmy into the seam located between the faceplate and the shell.
Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
Repeat until for each of the four clasps to fully release the faceplate from the shell.
Use a Phillips #00 screwdriver to remove all ten 8 mm screws securing the motherboard.
Use a hair dryer or a heat gun on low to apply heat to the back of the case while gently prying the battery out with an opening tool.
Set the battery aside for recycling.
Remove the plastic piece from the shell with a pair of tweezers from the inside.
