Introdução
The Eton Soulra XL has two woofers that are relatively easy to access and reconnect, should one become disconnected. This guide will provide step-by-step instructions to disassemble, clean, and repair loose connections. You will need to know how to solder; review Como soldar e dessoldar contatos if you are unfamiliar with the process.
O que você precisa
Gently pull down and out on the front cover; it should come off easily.
