Ir para o conteúdo principal
Ethernet Port Replacement
O que você precisa
    1. Ethernet Port Replacement, Linksys EA6900 Disassembly: passo 1, imagem 1 %32 Ethernet Port Replacement, Linksys EA6900 Disassembly: passo 1, imagem 2 %32 Ethernet Port Replacement, Linksys EA6900 Disassembly: passo 1, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Remove the antennas by unscrewing them from the base.
      • Flip over the device and locate the four rubber feet on the bottom.
      • Remove the rubber feet with tweezers
      Pergunte ao FixBot
      Comentar
    2. Ethernet Port Replacement: passo 2, imagem 1 %32
      • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Ethernet Port Replacement: passo 3, imagem 1 %32
      • Use a blue plastic opening tool to remove the top cover.
      • Move the blue plastic opening tool gently underneath the top cover from side to side.
      Pergunte ao FixBot
      Comentar
    4. Ethernet Port Replacement: passo 4, imagem 1 %32 Ethernet Port Replacement: passo 4, imagem 2 %32 Ethernet Port Replacement: passo 4, imagem 3 %32
      • Gently lift the motherboard and remove it from the case
      • Put the motherboard over a (preferably white) surface.
      Pergunte ao FixBot
      Comentar
    1. Ethernet Port Replacement, Ethernet Ports: passo 5, imagem 1 %32 Ethernet Port Replacement, Ethernet Ports: passo 5, imagem 2 %32 Ethernet Port Replacement, Ethernet Ports: passo 5, imagem 3 %32
      • Locate the Ethernet ports
      • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
      • Melt the 40 solder points using a soldering gun.
      • Wait between five and seven minutes for the ports to cool down.
      Pergunte ao FixBot
      Comentar
    2. Ethernet Port Replacement: passo 6, imagem 1 %32
      • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Denis
Membro desde: 09/15/16
611 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-1, Blackwell Fall 2016 Membro de USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Membros
Autoria de 24 guias
1Comentário do guia
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 64
Ao todo: 8,814
