Ir para o conteúdo principal
Equity Alarm Clock 13014 Alarm Replacement
O que você precisa
  1. Equity Alarm Clock 13014 Alarm Replacement, Alarm: passo 1, imagem 1 %32 Equity Alarm Clock 13014 Alarm Replacement, Alarm: passo 1, imagem 2 %32 Equity Alarm Clock 13014 Alarm Replacement, Alarm: passo 1, imagem 3 %32
    • Use a spudger to open and detach the wiring from the box holding the battery.
    • Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock.
    • Be careful while handling the box and clock to avoid any damage or injury.
    Pergunte ao FixBot
    Comentar
  2. Equity Alarm Clock 13014 Alarm Replacement: passo 2, imagem 1 %32
    • Use your fingers to remove the box.
    • Be careful not to apply too much pressure or force that could damage the box.
    Pergunte ao FixBot
    Comentar
  3. Equity Alarm Clock 13014 Alarm Replacement: passo 3, imagem 1 %32 Equity Alarm Clock 13014 Alarm Replacement: passo 3, imagem 2 %32
    • Use a soldering iron to melt the solder on each wire connection to safely remove the wires.
    Pergunte ao FixBot
    Comentar
  4. Equity Alarm Clock 13014 Alarm Replacement: passo 4, imagem 1 %32 Equity Alarm Clock 13014 Alarm Replacement: passo 4, imagem 2 %32
    • To replace the wiring box, use your hand to remove the old one and install a new one in its place.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 27
Últimos 30 dias: 91
Ao todo: 4,920
