Ir para o conteúdo principal
Epson VS250 Fan Replacement
O que você precisa
  1. Epson VS250 Fan Replacement, Shell: passo 1, imagem 1 %32
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
    Pergunte ao FixBot
    Comentar
  2. Epson VS250 Fan Replacement: passo 2, imagem 1 %32
    • Slide the cover to the right and lift the cover up and out to remove.
    Pergunte ao FixBot
    Comentar
  3. Epson VS250 Fan Replacement: passo 3, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
    Pergunte ao FixBot
    Comentar
  4. Epson VS250 Fan Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
    Pergunte ao FixBot
    Comentar
  5. Epson VS250 Fan Replacement: passo 5, imagem 1 %32 Epson VS250 Fan Replacement: passo 5, imagem 2 %32
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
    Pergunte ao FixBot
    Comentar
  6. Epson VS250 Fan Replacement: passo 6, imagem 1 %32
    • Remove the front cover from the projector by pulling it off of the device.
    Pergunte ao FixBot
    Comentar
  7. Epson VS250 Fan Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
    Pergunte ao FixBot
    Comentar
  8. Epson VS250 Fan Replacement: passo 8, imagem 1 %32
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
    Pergunte ao FixBot
    Comentar
  9. Epson VS250 Fan Replacement, Fan: passo 9, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the five 10 mm screws.
    Pergunte ao FixBot
    Comentar
  10. Epson VS250 Fan Replacement: passo 10, imagem 1 %32 Epson VS250 Fan Replacement: passo 10, imagem 2 %32 Epson VS250 Fan Replacement: passo 10, imagem 3 %32
    • Unplug the fan connector from the circuit board.
    • Remove the wires from the hooks that secure them to free the fan.
    Pergunte ao FixBot
    Comentar
  11. Epson VS250 Fan Replacement: passo 11, imagem 1 %32 Epson VS250 Fan Replacement: passo 11, imagem 2 %32
    • Disconnect the wire and remove the black casing from the rest of the fan assembly.
    Pergunte ao FixBot
    Comentar
  12. Epson VS250 Fan Replacement: passo 12, imagem 1 %32 Epson VS250 Fan Replacement: passo 12, imagem 2 %32
    • Remove the fan from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Warren Cutlip
Membro desde: 09/28/21
604 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 4-2, Hunter Fall 2021 Membro de Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 728
